Im sure this is an easy one for someone but I’m unsure how to approach it. Im trying to back up my copy of Behind Enemy Lines (NTSC). IFOedit shows it as having 1 PGC so I have chosen the Doom9 DVD-9 to DVD-5 "Full Copy" method not the Scenarist method. The movie is in VTS_04_X.VOB and in front of the movie is a few minutes of menu video and the chapter stills with it’s own audio track. The audio track is longer than the menu/chapters sequence because the audio plays while the chapters screens are frozen. My problem is how to set it up in maestro in order to author it. If I bring in my new video stream it has the menu and chapters at the front (1.38 min approx). When I add the movie audio it has to be off set by 1.38min to be in sync. Then I add the menu/chapters audio which doesn’t have to be offset but looks funny as it appears to over laps into the movie. Any chapter or subtitle import will be out of sync by 1.38 mins. Or do I cut the video so I bring in the menu/chapters as movie1 with it’s audio track and bring in the main film as movie2 with it’s audio track. If so is it possible cut the video in maestro or should I uses tools in TMPGenc?
Results 1 to 1 of 1
Getting "Fair Use" copy of last "Byrds of Paradise" episode
By Ronald Vaughan in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2010, 22:09 -
Can I bypass "copy blocker" to copy from VHS to DVD
By jgloeckner in forum Newbie / General discussionsReplies: 10Last Post: 23rd Nov 2008, 00:40 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20 -
TMPGEnc DVD Author 3 DivX "Smart Rendering" Bug?
By ln108 in forum Authoring (DVD)Replies: 7Last Post: 23rd Aug 2007, 12:27 -
Problem "Full processing mode" in VirtualDub
By jonaskarlsson in forum AudioReplies: 11Last Post: 11th Aug 2007, 22:30
