Hey, i have bad frames in downloaded divx file, and was informed that i need to recompress the divx file to remove these bad frames. anyone know how to do this, or how to fix my bad frames problem, as TMPGEnc crashes when encoding it, the audio carries on, but the video freezes. cheers for any help![]()
No u dont have to recompress it but you will need to delete these badframes and resync the sound, go to:
http://www.vcdhelp.com/forum/userguides/135552.php -
ok my file had 2 .avi files, the first was corrected relatively easily, but the second disc has lots of bad frames, and if i deleted these, a good 2 sec chunk would be missing, so does anyone know how to correct bad frames? is that possible? cheers for any help
I've never tried this so I don't know if it will work (I'll try it next time I've got a corrupt section):
you might try saving out a small selection containing the corrupt portion as a small avi then run it through divfix (rebuild index) to see if it fixes the data. If it does then append it back into movie.
I've always just deleted the corrupt data myselfyou know it's the anti-Midas touch when all you touch goes to shit.............. -
yeh ive just deleted them out, but sometimes are quite noticable. i will try that method next time i need to fix a divx. thanks for the help, ive now encoded and recorded my movie to VCD, which works perfectly on both DVD player and my computer! im well chuffed
Bad frames are junk, there is nothing there that can be fixed, green colours artefacts etc.. Nothing you can do but delete them. Sometimes the frames have been added during downloadOriginally Posted by neenyrules
deleting them will return the movie to normal
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
