Major, I used ffmpegX to convert Star Wars AOTC to DivX (perfectly in sync, BTW). I know you can convert directly from the DVD but I chose to rip to my HD first. When you rip to your HD first, is the option to encode subs still available? I ripped the subs with 0SeX (second set for alien subtitles) and chose the "Encode Subtitles" option and chose subs #2. But, it did not encode them. Do I need to do something different to get them encoded? Also, I've never really messed with DivX before so I was wondering what settings I should use for the highest quality? Does two pass encoding really make a difference?
Yes.Originally Posted by SCB
If you only ripped one set of subtitles then you should choose subs #1.Originally Posted by SCB
Presets + set best bitrate by choosing proper image size and using the "Calc best" calculator.Originally Posted by SCB
It can optimize file size. I don't use it that much.Originally Posted by SCB
problems installing add'l software for ffmpegX: mencoder
By Tomtom2011 in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2010, 18:47 -
Problems with ffmpegX 0.0.9y and mencoder on MacOSX
By anto1973 in forum ffmpegX general discussionReplies: 11Last Post: 16th Oct 2008, 01:42 -
[RESOLVED] ffmpegx 0.0.9y keeps asking for install of mencoder
By breggol in forum ffmpegX general discussionReplies: 1Last Post: 5th Oct 2008, 05:23 -
mencoder rotates, why not ffmpegX?
By PhilippeP in forum ffmpegX general discussionReplies: 1Last Post: 13th Apr 2008, 16:43 -
No luck with ffmpegX - mencoder segmentation fault.
By jonnymorris in forum MacReplies: 4Last Post: 2nd Mar 2008, 14:07
