Hello !
I am trying to rip a vob file on a DVD-R using ffmpegX 0.0.5 but I receive this error message:
/Users/user/Desktop/ffmpegX.app//Contents/Resources/mkisofs: No such file or directory. Faild to read VIDEO_TS.IFO
/Users/user/Desktop/ffmpegX.app//Contents/Resources/mkisofs: Can't open VTS info.
/Users/user/Desktop/ffmpegX.app//Contents/Resources/mkisofs: Unable to make a DVD-Video image.
Settings are like this:
- Video Codec "MPEG2"
- "hi-bitrated DVD (PAL)" in the Quick Presets menu
- Autosize to 4:3
- Audio: PassThrough
- Calc rate for the nmb min on one 4GBDVD-R
- checked QT decode (No SVCD scan, Bicubic, VOB letterbox, Altivec were already checked)
- Author as DVD (VIDEO_TS) under MPEG 1/2 post-processing (options)
Please help me !
Thanks !
Polopo
Here is the whole log:
Last login: Sat Jan 11 04:21:31 on ttyp2
pbpaste | sh
Welcome to Darwin!
[Lsne-CaTV-dhcp-42-130:~] user% pbpaste | sh
a52dec-0.7.4 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
No accelerated IMDCT transform found
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 4294967256 bytes
INFO: slots/frame = 672
INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
INFO: System is big endian
1566 frames in 47.30 sec (33.11 fps), 31 last 0.85 sec (36.47 fps)
1574 frames decoded in 47.31 seconds (33.27 fps)
INFO: Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Users/user/Desktop/movieVIDEO_TS/movie.mp2"
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Users/user/Desktop/movieVIDEO_TS/movie.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Users/user/Desktop/movieVIDEO_TS/movie.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
INFO: [mplex] Selecting SVCD output profile
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/user/Desktop/movieVIDEO_TS/movie.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 544
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 3538000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/user/Desktop/movieVIDEO_TS/movie.mp2)
INFO: [mplex] AUDIO STREAM:
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 3833600
INFO: [mplex] Setting best-guess data rate.
INFO: [mplex] Sectors = 78 Video delay = 34045 Audio delay = 34045
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 235520 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 381
INFO: [mplex] STREAM e0 completed @ 381.
INFO: [mplex] STREAM c0 completed @ 2097.
INFO: [mplex] Multiplex completion at SCR=4560316.
INFO: [mplex] Video e0: buf= 235520 frame=000381 sector=00002369
INFO: [mplex] Audio c0: buf= 2752 frame=002097 sector=00000615
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 675705 bytes
INFO: [mplex] Sequence headers: 26
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 382
INFO: [mplex] No. Groups : 26
INFO: [mplex] No. I Frames : 26 avg. size 31064 bytes
INFO: [mplex] No. P Frames : 103 avg. size 15727 bytes
INFO: [mplex] No. B Frames : 253 avg. size 11816 bytes
INFO: [mplex] No. D Frames : 0 avg. size 0 bytes
INFO: [mplex] Average bit-rate : 2830000 bits/sec
INFO: [mplex] Peak bit-rate : 3330000 bits/sec
INFO: [mplex] BUFFERING min 54 Buf max 144720
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 1409856 bytes.
INFO: [mplex] Syncwords : 2098
INFO: [mplex] Frames : 2098 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 67 Buf max 683
INFO: [mplex]
INFO: [mplex] MUX STATUS: no under-runs detected.
STAT: Processing /Users/user/Desktop/movieVIDEO_TS/movie.mpg...
sh: line 1: 3895 Segmentation fault ./ifogen -A mp2 -o VTS /Users/user/Desktop/movieVIDEO_TS/movie.mpg >/Users/user/Desktop/movieVIDEO_TS/movie.DVD/VIDEO_TS/VTS_01_0.IFO
tocgen running
scanning /Users/user/Desktop/movieVIDEO_TS/movie.DVD/VIDEO_TS/VTS_01_0.IFO
Total translation table size: 0
Total rockridge attributes bytes: 0
Total directory bytes: 4096
Path table size(bytes): 42
Max brk space used 0
304 extents written (0 Mb)
Encoding complete!
Results 1 to 1 of 1
FFMpegX - NOT seeing VOB's imbedded subtitles...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 14th Jan 2012, 09:10 -
ffmpegX problem
By air in forum ffmpegX general discussionReplies: 1Last Post: 7th Nov 2008, 12:17 -
VOB to mpeg2 convertor - not ffmpegx
By faxfan2002 in forum MacReplies: 8Last Post: 30th Jan 2008, 03:36 -
ffmpegx problem
By illuzion13 in forum ffmpegX general discussionReplies: 3Last Post: 9th Jun 2007, 14:34 -
single .vob in ffmpegX to h.264 (mencoder) .mp4 a/v sync issues
By jabroni5 in forum ffmpegX general discussionReplies: 15Last Post: 7th Jun 2007, 16:48
