i want to cut an avi file with virtual dub and i want to be very precise. i choose a "mark in" and a mark out, when i play my selection in a player, i can see that the mark in is not the one i've chosen (about one or two seconds before). is virtual not precise enough ? how could i do to get a good result ?
thanks...
Originally Posted by mattei59
I never search backwards in this kind of movie. I always search forward, one frame at a time and when I get to the frame (or frames) I want to cut, I press the in and the out markers and delete the frame. By setting the in marker and moving forward, one frame at a time, you will be certain only to delete the frames you want.
If you're not satisfied with the way the cut looks, you could save in two parts and use an editor with transition filters to blend the different scenes together. -
This guide can help you cut properly with VirtualDub:
http://www.vcdhelp.com/virtualdubedit.htm
Hope That Helps!!! :P
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 21:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 17:27
