I am having problems capturing sound with Virtualdub. I have checked all the Line-In audio properties, i.e., not muted, volume up, Recording line-in, etc. I can even hear the audio through my speakers. I can also capture fine in PowerVcrII. The problem is that Virtualdub is a better quallity capture.
Also, I am having problems with the video settings using PicVideo MJPEG. Whenever I try to select 720x480 it says "unsupported format". I used some resolutions found in the guides here and they too are showing the same error. It only gives this error when trying to use YUY2.
Any comments would be appreciated, thanks.
