The compability list says that this player supports up to 2500kbits XSVCD why is this value lower then SVCD standard 2600kbit?
Am i wrong to think that the XVSCD in the list is the same thing as XSVCD ? If it's not the same, what is XVSCD ?
I'm greatfull for all the help i can get.
/ Fredrik
unfortunatly it is, u cannot use SVCD that goes to 2600, but i wouldnt worry to much, if it does itll just stutter a little, its VBR, so it wont really stay like that. as far as creation just make 2500 the max.
they don't officially support the SVCD spec on their players. in fact, if you call tech support and ask about it, they will usually tell you they don't make and SVCD-compatible players. the players "just happen" to play SVCD discs < 2500kbps.
also, in relation to SVCD vs XSVCD, XSVCD is any non-SVCD compliant but SVCD-structured disc. reasons for noncompliance can include the following (non-exhaustive) list:
higher than 2600 bitrate
any higher than 480x480 resolution (NTSC)
any lower nonsupported resolution (176x144, 640x240, 360x480, etc)
mpeg-1 clips
<font size=-1>[ This Message was edited by: patrickm on 2001-07-06 09:54:37 ]</font> -
Thanx for your replies guys. Does it go up to 2500kbps video. Or do i have to include audio in this number too?
Like if i want 192kbps sound, do i have to choose a lower bitrate then?
/ Fredrik
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
LG LDV-535 Remote control Codes
By Lukas2k in forum DVD & Blu-ray PlayersReplies: 0Last Post: 4th Oct 2011, 21:32 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
I am confused about the DTS playing capability of my Pioneer DV-393-S...
By oleglelchuk in forum DVD & Blu-ray PlayersReplies: 7Last Post: 18th Apr 2008, 22:34
