I just upgraded from Windows ME to Windows XP. Now when I try to convert an AVI file to MPEG 1 using TMPGEnc , like I have been doing for the past two years with ME, all I get is a black screen. It creates the output file with good audio, file size looks right, but it is just a black screen. Also as it decodes the screen is black.
Anybody know what this might be from?
I have reinstalled my Divx drivers, etc....no effect.
I also downloaded and installed DirectX 9.0...no effect.
That's why I rarely do OS upgrades, some of the registry entries, dlls, program settings, etc., from the older operating system may carry over and cause problems. If you don't get it going any other way, I would suggest a new/clean install of Windows XP, as in reformatting the boot partition and starting from scratch.
agreed, i tried to upgrade, and in the win xp cd where it says checking syetm for incompatabilitie, it came up with a list of progs, which i always use so i didnt bother, but a friend said never upgrade, just format and install, i did and all works fine, inc. the progs it said wouldnt work[/b]
Up until late last year I ran Win98 since it first came out on the market. I burned quite a few VCDs with that system until I updated to XP. I didn't bother upgrading, I just did a clean install and dumped all my VCD programs on the box afterward. I have yet to experience a show-stopper with VCD creation. I've had glitches, but never a problem. I think if you do a clean install of XP, add all the service packs much like I did you probably would be fine. It's just that I heard horror stories of upgrades going squirley because of incompatibilites with dlls and registry entries. Anyway, good luck!
The itsy bitsy spider climbed up the water spout. Down came the Goblin and took the spider out. -- Spider-Man, 2002
Can't framerserve vdub to tmpgenc under Windows 7 64 bit
By TheFamilyMan in forum Video ConversionReplies: 2Last Post: 8th Nov 2009, 19:29 -
Windows Update Problem
By bevills1 in forum ComputerReplies: 17Last Post: 12th Jun 2009, 13:01 -
Problem Capturing DV with Windows 7
By monoxide77 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Jun 2009, 15:31 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Windows Color Profiles ignored by TMPGenc, VirtualDub, etc. ?
By sanlyn in forum Video ConversionReplies: 13Last Post: 28th Jun 2008, 10:42
