Im trying to play vcd's for the first time on my cd-rom.
I can hear the drive running.. but nothing happens.
I downloaded powerdvd.. nothing happens.
I downloaded scsi1help.vxd.. nothing happens.
I try to access the drive.. says drive is not accesable, incorrect function.
Im running windows 2000.
Is it my computer? Or the VCD?
Any advice would be helpful.
Thanks.
two ok things are possible:
1. it's a mode 2 CD, holds more data (like 800 MB for the 80 MIN) but has an inferior file system (takes a while to load the data). maby you should give it like 3 or 4 minutes for a 30 or so speed drive
2. use i-on VCD player, it's great. Of course if after 3 minutes you cannot go to the drive in "MY COMPUTER", and look at it, it's just not being recognised as valid for some reason, dunno why. -
Originally Posted by SECRETANGEL
X = your CD-ROM
Video runs locally but not when downloaded
By Esinem in forum Video ConversionReplies: 4Last Post: 6th Oct 2009, 22:48 -
convertxtodvd suddenly runs very slow
By aruwin in forum Video ConversionReplies: 13Last Post: 25th Jul 2009, 01:39 -
Fantastic, runs on Windows 7 64-bit!!!
By RealJB in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2009, 10:34 -
Laptop runs REALLY SLOW!
By Squid_uk in forum ComputerReplies: 22Last Post: 6th Oct 2008, 22:34 -
video runs slow
By Madgelina in forum EditingReplies: 0Last Post: 8th Feb 2008, 17:45
