Hello,
I just wanna ask : Is DivX the best choice for video formats?
I heared that DivX can have the same quality with DVD's with less megabyte. I wanna store lots of video files in my hardrive. If that is correct, do you know some websites that can help me convert files to DivX?
Thanks!!!!!!![]()
DivX or XviD are mpeg4 codecs. They're great if you intend to play it with your computer. (It won't play in a DVD player) You can watch it on your monitor or on a TV if your video card has a TV out. Some people like DivX, some like (S)VCD's better. Every way has it's pros and cons. One piece of advice, if you're going to go the DivX way, you want to use Gordian Knit. It's more complicated than some other programs, but it's by far the best.
Stupid Divx HD on PC Question
By belfastrab in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2009, 00:18 -
DIVX player question
By slats7 in forum Video Streaming DownloadingReplies: 4Last Post: 25th Sep 2008, 07:10 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
DivX question
By didikai in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2008, 20:22 -
Divx converting question
By KilinKind in forum Video ConversionReplies: 2Last Post: 15th Jan 2008, 18:25
