I just wonder about the DTS sound. I can't use it with my turtle beach soundcard, and i detected that it took over 1 gb of space when I should do a backup of THE OTHERS, whitout the DTS sound the movie did fit in nice on a 4,7 gb without no encoding 8) !
So I just wounder when or to what do I use the DTS sound???
You need a receiver or sound card that can decode DTS sound. Some DVD players have a built decoder for Dolby Digital and/or DTS. There are web sites you can check out for the difference between the two, but I believe DTS uses a higher sampling rate for the audio, thus resulting in overall better tonality. If the DVD has both and you want to sane some space or are trying to make it fit on a single layer DVD, I would say just rip the Dolby 5.1 track.
if you want the dts track (which sounds better) you will have to also have an ac3 track (can be just a low bit rate 2ch track)
DTS sound from DVD
By night_flight in forum Authoring (DVD)Replies: 8Last Post: 11th Apr 2012, 18:59 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Please Help? How to restore DTS sound on DVD
By amir3852 in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2011, 16:31 -
MKV2VOB problem with DTS sound...
By theria05 in forum Video ConversionReplies: 1Last Post: 30th Jan 2010, 04:17 -
authoring program with dts sound
By tommcd64 in forum Authoring (DVD)Replies: 3Last Post: 25th Feb 2008, 12:59
