Hi,
I just used TMPGenc to convert a dat file to an mpg using the info on the corresponding page of your site (very useful by the way).
I now have an mpg file but cannot open it in windows media player.
Is there another step that I need to take before I am able to play the movie in the mpg format?
Cheers,
Jon
Sorry, it wasn't tmpgenc, it was VCDgear gui.
I got confused because of all the editing I'm doing.
Please help me out. J -
Why not just rename it to filename.mpg?
I have never had any probs with just changing the file name. I know sometimes changing the extension is difficult in windows so just use dos.
in dos just type:
COPY AVSEQ01.DAT FILENAME.MPG
In a few minutes you will have your MPEG file ready for viewing
Easy!
Just make sure you are in directory where the dat file is
This always works for me whether in NT, 2000, XP Haven't tried it with 98 though because I like XP so much and don't want to go back.
Hope this helps
Anthony
TMPGEnc for HD to SD conversion?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 20Last Post: 14th Oct 2011, 17:37 -
DAT to DAT cutter?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2010, 12:13 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 13:57 -
TMPGenc TS FPS Conversion
By leftofcool in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 08:39 -
TMPGEnc Conversion 15hrs remain?!
By Squid_uk in forum Newbie / General discussionsReplies: 35Last Post: 1st Jun 2007, 14:01
