I'm using Pinnacle DVD Impression. The programme accept only separate streams of audio and video. From TMPGEnc I can only output either an audio or video stream at the same time. I'm aware of the demux options and the option of outputing the audio as a wave file, but this is either time consuming or a size issue(wave). I just want to know if it's possible to output both streams at the same time.
If not, I can always use the MPEG encoder built in Premiere 6.5
Tmpeg's current version has an option to encode as elementary video and audio streams at the same time. I believe this option is available with version 2.58 and above. I have 2.58 and 2.59 and they allow it.
Demux a Dolby Surround 2.0 file into separate streams?
By Xoanon in forum AudioReplies: 27Last Post: 2nd Jul 2021, 08:21 -
MOV with 25 separate streams.
By sikm in forum Software PlayingReplies: 2Last Post: 14th Oct 2011, 01:52 -
Separating the channels in a 5.1 stream into separate streams
By FallenAngelII in forum AudioReplies: 2Last Post: 7th May 2010, 02:37 -
Use to author from separate audio and video streams?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 14th Jul 2009, 05:41 -
100% CPU Usage while outputing from TMPGEnc DVD Author
By lj01 in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2008, 10:09
