  1. I try to create a DVD with nerovision but when creating chapters the audio is out of sync. The files I am using are already encoded in MPEG-2. Can anyone help?
  2. Originally Posted by JMBoers
    I can't help, but I just made an SVCD from Divx4 files using nerovision. Seemed great and soo easy. Then I watched the finished product... how sad. My title menu was blown up huuuuge and the audio on my movie was so friggin out of sync it was rediculous(sp?). The vocals were about 15-20 seconds after the action. TERRIBLE. Gonna try another method in a few. Will let you know if it's a better method.
  3. Member tonytyke's Avatar
    Sep 2003
    Yorkshire, England
    I used Nerovision as well, and the first few Avi files I converted were fine. However, now some work fine, and some don't.
    I thought it was down to the codec that I was using. Checked, and installed the correct codec (the films now view in Real Player) which hasn't fixed the problem. I did buy 1x discs ... maybe I'm recording too quick ??
    Any help?????
    T.
    Apr 2003
    my computer, where else?
    try the new update v2.0.1.9. might help.
    http://www.nero.com/en/nero-up.php
    I said I'll be done in a minute. I meant a Microsoft minute.
  5. Why use nero? There are better software around.Eg. Ulead Movie Factory
    better still DVD workshop
