Can someone please tell me why Nero wont burn my svcd image that I created with dvd2svcd.
It sais the file is to large but I have enabled overburn on nero.
It should not be too large cause it was created with the standard svcd2dvd
parameters.
Is there another program out there that will burn svcd images created by dvd2svcd?
Thanks to everyone for there help in advance
both you and me are in the same boat then... i too have been having that problem... if i find a solution i will let you know
You win some, and you lose some, and some get rained out... -
ok ryanreko and anyone else who is interested in solving this problem
I tried this and it works perfectly for me
Start fron the beginning
in dvd2svcd go to the bitrate tab
then
change the cd size from 800 to 740
all of them
then
where it sais between 0 to 50 lessen the 50 by 5 and do so all the way down to the bottom
so it reads like this.
0-45
45-58
58-97
97-120
120-165
it seems to me that when you create an image it makes it slightly to big for nero to fit on a 80min cd
Well anyway i hope this helps you guys out there
It worked perfectly for me -
@Im A Newbie
It's true that DVD2SVCD creates image files that are slightly larger than they sould be. I have found that if you set the CD size to 790 instead of 740 then the resulting image files are usually exactly 80 mins long, those extra 50 megs can really count quality-wise...
I had problems with both DVD2SVCD and nero. DVD2SVCD just refused to encode the last part saying there was not enough space on disk and therefore could not write to ini file, but I used VCD Easy which is far easier and better IMHO
However when I burned using Nero there was a audio sync problem. worked fine in the computer, but not on my Tosh Hardware modified set top box.
I tried Win on CD 5 Power edition and it now all works fluffy
VCD easy might not have the same control over the end result as dvd2svcd for the newbie but it can be altered if you go into each program individually and save the changes
However each DVD creates 2-3 CD's worth and the results are top notch and there would be no reason why you could not create a single file rather than 3 and burn it to a DVD instead
Hope this helps
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Can't burn video TS with nero
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2008, 03:19 -
Burn Failure (Nero 7)
By TunkaFrankie in forum DVD & Blu-ray WritersReplies: 26Last Post: 11th Sep 2008, 23:35 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11
