Standard phone line modem are regulated by the FCC to 53.3 kbps max. You'll never see 256 with any type of hardware or software modification. The only thing you can really do is modify the mtu speed setting in the windows registry. This setting is by default set to work with high speed connections, not dailup. MTU stands for maximum transmitable units. Best setting for a dailup modem is 576. You can edit this manually or with
software like mtuspeed (which is freeware). If you want to try it out, you can download it from here. mtuspeed410.exe.
http://home.earthlink.net/~bagmaster51/
Results 31 to 33 of 33
If it works, don't mess with it, don't tinker with it and don't break it.
Betamax: I'd be glad to get DSL... or Cable. Or even the beam? has anyone here heard of the beam before? Its gone now and was crap but it was fast. Sadly I live a little to far out of the Dallas/Ft. worth area for any of it. Instead its 56k ville.
yea - they had direct microwave link up's here also - for awhile .. still see the ant. around .. but the company isnt ... fast but they lost big time money on it ..
New modem - DOCSIS 3.0, anything I should know?
By Xylob the Destroyer in forum ComputerReplies: 1Last Post: 5th Dec 2009, 21:13 -
How can I get 56K on my laptop? What hardware do I need?
By Xenogear900 in forum ComputerReplies: 1Last Post: 11th Jun 2009, 12:01 -
canot connect to modem
By romanstopme in forum ComputerReplies: 5Last Post: 17th Dec 2008, 13:39 -
Which modem router to get?
By Tbag in forum ComputerReplies: 3Last Post: 1st Jun 2008, 17:54 -
XP won't install 56k modem
By zanos in forum ComputerReplies: 7Last Post: 5th Jul 2007, 21:25
