what is the best program to make a backup of a movie allready on a DVD-R to another DVD-R? I have used RecordNow (not MAX) and the DVD-R's i get out of that work for about 30 minutes and then get all pixelated and skip and finally stop playing. I know the orgional DVD-R that i'm trying to make a copy of works just fine. TIA!
Results 1 to 9 of 9
i'm using HP recordNow,never had any problems making an exact copy of a dvd-r
It's worth a try...................Good luck!!!!
Jesprulin. -
HP Record Now is just a version of Veritas Record Now, but it ships with the HP recorders.
use dvddecrypter to make an iso
use dvddecrypter to burn the iso
life is simple -
You should buy a verbatim dvd-rw disc, this showld work on every standalone player. If it works you know it's not a software problem but a cheap disc problem.
Ben. -
Like boas999 said.. DVD Decrypter is about the simplest way of copying a dvd-r.
i would really like to just make a 1 to 1 copy, direct from my dvd-rom drive to the dvd-r drive. is there a way to do that?
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
