    Jul 2001
    Richmond, VA
    I ripped the entire disk which came out to be about 4.9 gigs. I know that if I strip two of the audios it will be small enough to fit on 1 DVD. I tried to do this before with IfoEdit with no success. The problem is that I want to keep all the menus and extras. Is there a way to use Ifoedit to strip the audio out and maintain all the extras. Thanks in advance.
  2. yes that is possible and simple. look at the guides at www.doom9.org, there is alink to the guides under the guides here.
