I just ran into a pleasant surprise with my new HDTV (wide screen). I had a home digital video taped at 16:9 ratio. When I play this on my new HDTV, the whole thing fits the screen exactly (no black bars top/bottom). Another second surprise is after transferring this tape to my DVD recorder, the resulting DVD disc plays same as the tape, i.e. the picture fits the screen perfectly.
Now is the non-pleasant part. When I play this DVD disc on a regular TV (4:3), then everyone in the movie look tall and thin. I guess they must be happy seeing themselves that slim, but that's not what I like.
Is there anything I can do when recording the DVD disc so that when I play on the regular TV, there will be black top/bottom bars to maintain the 16:9 ratio as commercial DVD ? How does the commercial DVD make this happen ?
Results 1 to 10 of 10
ktnwin - PATIENCE
Look at the DVD players setup menu. There should be a screen to determine 4:3 P&S,4:3 LTX,and 16:9,it maybe a change in that setting will work.
Already tried, it did not work. I have seen somewhere mentioning that each DVD contains a DAR (display aspect ratio) flag. the DVD player keys of this flag to squeeze the video vertically on the 4:3 TV. If you setup for wide screen then this flag tell the player to leave it alone.
So, my main question is when you author your home DVD, how do you set this DAR field ? Does any authoring software support this ?ktnwin - PATIENCE -
What authoring program are you using? How are you encoding it to MPEG-2? What software do you use to capture the video?
My guess is that you need to use something like TMPGEnc to convert your captured video to and MPEG-2 file with 4:3 aspect ratio. I'm not 100% sure that TMPGEnc can do it, but you could try. You can then author a DVD menu with two choices so the viewer can select which format he wants to see. -
Actually, the following method gave the same results
1) use standalone DVD recorder, it copy anamorphic digital tape as anamorphic DVD
2) use Studio 8 to capture, encode and burn disc
3) use Studio 8 to capture, TMPGEnc to encode (keeping 4:3 aspect ratio)
In any of these methods, the video is treated as 4:3 aspect ration (squeeze horzontally).
That's why they play great on wide screen TV (perfect fit). And they are squeeze horizontally on 4:3 TV.
Any software out there allow me to set DAR aspect ratio ? (so it works like commercial DVD movies).ktnwin - PATIENCE -
You want to author an apomorphic DVD. This is a DVD where the m2v video is 720x480 (the picture takes up the full resolution). You then flag the movie as either 16:9 or 4:3. I only know how to do this is DVD Maestro.
As Wulf109 said thou, you also need to have your DVD Player setup correctly to play the apomorphic disc. -
if you still have the m2v file, you could change the pixel aspect ratio in the video stream with "pulldown.exe ... -aspect_ratio 16:9"... and then also set the display aspect ratio to "16:9 letterbox" in your authoring program (or patching the authored files with ifoedit).
hopefully, the "black bars" will show up on 4:3 displays while keeping the 16:9 aspect ratio.
not sure if this method will work, please let us know if you try it? -
Yes pulldown.exe should do the trick. I've done this myself with SVCDs to create anamorphic WS SVCDs, but not many DVD players detect the flags properly for SVCDs, but they should for DVD.
Does anybody know if it's possible to record the pan&scan info on a DVD? I seem to remember this being touted as one of the benefits of DVD (i.e. P&S and WS on the same disc), but I've never seen any discs that use it.
Dave -
noobee,
thanks for the suggestion, that's exactly what I am looking for.
I will try it and let you know.ktnwin - PATIENCE
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 16:38 -
new recorded dvd can not be played or recorded on after the recording is do
By dlaleh1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Jan 2010, 23:06 -
Recent recorded hom evideos to DVD now in Mpeg2 format... what to do?
By tehfreeman in forum Video ConversionReplies: 2Last Post: 19th Dec 2008, 13:07 -
Editing, Creating DVD from "Microsoft Recorded TV show" format
By mb90078 in forum Media Center PC / MediaCentersReplies: 6Last Post: 8th Aug 2008, 20:40 -
Any free software to convert a recorded dvd into youtube format
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 4Last Post: 5th Aug 2007, 13:07
