Is it possible to convert wav to DD 5.1. The reason I ask is because the audio file wou be smallertherefore leaving more space on the dvd-r. Hope this is not a stupid question.
nc.
yes you can convert ... you will need to purchase a ac3 encoder though (software or hardware) , software starts about $400 for 5:1
Thanks for the reply. What software is available to do this.
nc. -
well there is this freeware one - but it looks as if it may be a bit shaky yet .. http://oss.netfarm.it/ac3encode.php
other ones
Besweet (guide found here - use at own risk) free
SEK'D AC3 Encoder
Nuendo w/ ac3 plug in (expensive)
Minnetonka Audio's Surcode
Sonic ac3 encoder (part of scenarist) (expensive)
Sound Forge ACID w/ ac3 plug in
a few others ..
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 23:45
