I have used rempeg2 lots of times, but sometimes I get a strange situation where it basically hangs. I've looked on several forums for someone with a similar problem but have found nothing.
I start encoding and get the following.
transcoding started...
setting up vbr-controller using slected options
pass 1...
decoder thread started...
encoder thread started...
decoder done...
..then it just stops and does nothing.
I'm currently trying to backup PAL Matrix but I've had probs with X-Men as well. It doesn't seem to matter which encoding options I use. I daresay this is a really obvious problem but I'd REALLY appreciate some help on this.
cheers
I know 99% sure what your doing wrong. I did the same before.
You need to make an .cffl file like this (on some kind of tutorial, doom9):
CFFL
xxx_01_0.vob
xxx_01_2.vob
xxx_01_3.vob
xxx_01_4.vob
Make it this way:
CFFL
c:\xxx_01_0.vob
c:\xxx_01_2.vob
c:\xxx_01_3.vob
c:\xxx_01_4.vob
Where c:\ is the directory & hard disk where you saved your vob's
That will fix your prob!
Have phun! -
Thanks for such a quick reply. Unfortunately, I've already done what you suggest!
Rempeg usually works for me. I just can't work out what's going on with this one.
cheers -
To other peepz -> it worked this way, Hot Rats pmed me and everything was fine
Greetz
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 15:12 -
How do I start?
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd Dec 2009, 08:29 -
MeGUI wont start encoding video when using Avysinth...
By Charmer in forum Video ConversionReplies: 2Last Post: 6th Aug 2009, 19:19 -
What is this start up ?
By DuBsTaR in forum ComputerReplies: 9Last Post: 20th Nov 2008, 08:53 -
Looking to start HD capturing...
By RockWood610 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 2nd Apr 2008, 18:42
