I just read a thread where it said that you're supposed to get audio, as well as video while TMPGEnc is running.. The guide that I'm using doesn't instruct me to input an audio file.. Anyone? Please don't tell me I've bothced another process...![]()
while its encoding you're not supposed to hear audio. if you want the end file to have audio you can input it in tmpgenc. or you can convert the audio in another program and then mux with the m1v or m2v file you get with tmpgenc.
You you will not hear audio while TMPGenc is encoding/running, you will only see the video as it's processed.
The final MPEG should contain both audio and video. However, you need to tell TMPGenc what audio and video file to use. If you're encoding a DivX when you open the video source the audio source will be loaded as well. -
....but be careful when encoding from a DivX source. Audio from DivX might get out of sync when encoding the MPG, if the original AVI was encoded with a variable bitrate. I always extract the audio from the original AVI as an uncompressed WAV file before encoding in TMPGEnc. Once that's done I make sure to point TMPGEnc to this 'new' audio source. No sync problems.
MeGUI hangs on pre-processing after extracting audio tracks
By CasanovaFly in forum AudioReplies: 2Last Post: 31st Jul 2011, 09:25 -
TMPGEnc Plus not processing to specified parameters!
By Thommers in forum Video ConversionReplies: 5Last Post: 16th Dec 2009, 00:21 -
mkv video audio normalization / post-processing audio normalization
By o6uoq in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2009, 00:17 -
Is it supposed to take this long?
By blaqlion22 in forum Authoring (DVD)Replies: 1Last Post: 20th Jun 2009, 07:41 -
Issue with Xvid audio sync after YouTube processing
By brassplyer in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Jun 2008, 04:59
