Thread: DRX500ul (DRU500a) and RecordNow Max only at 1X?
  1. #1
    I'm using the external firewire version of Sony's DRU500a. I've been using RecordNow DX burning to Verbatim DVD-R 2X media, and it successfully burns at 2X. However, when I try RecordNow Max (version 4.5) with the same media, it will only burn at 1X. In fact, no matter what media I use RecordNow Max will only burn at 1X. Has anyone else seen this? How do I get it to do 2X and above?
    friley,
    Try the following:
    In RecordNow DX go to the "tools" selection in the top menu. Select "options" in the pull down menu. Make sure "Remember settings from the last time you started a job" is not checked. Set record speed to "MAX"
    Dave
    Member donpedro's Avatar
    Aug 2002
    EU
    Posts
    3,533
    Sory... can't help you there... But what is difference between DX and Max ? A lot of people are talking about it as it is same but name difference make me think that it is not.
    Member
    Nov 2002
    Australia
    Posts
    90
    DX came with my Sony DRU500A and has only a Wizard interface with limited options.
    Max has the full RecordNow interface with more options that you can select. Download the eval and check it out....
    _________________
    Peka + Drugs = :o
    Aug 2002
    EU
    Posts
    3,533
    Quote Originally Posted by Peka
    Sorry Peka but RecordNow DX have "full" interface too. Original RecordNow is only wizard. And maybe I will download Max... I just don't want to braje DX that I have now.
    Member
    Nov 2002
    Australia
    Posts
    90
    Donpedro:
    Hmmm, so what version of DX do you have? Mine is 4.50, but I actually can't see DX anywhere in the Help>About screen. Mine is the version that came with my DRU500A - is that where you got yours, and do you know if there's an upgrade?
    Thx
    _________________
    Peka + Drugs = :o
    Aug 2002
    EU
    Posts
    3,533
    You need to upgrade to get DX.
    My says,
    Veritas RecordNow DX 4.56
    Go here to get more info:
    Sony DRU-500A Updated sofware ??? (DLA, RecordNow DX, MyDVD)
  1. Anyone here use 3DS MAX?
    By Rudyard in forum Computer
    Last Post: 25th Jul 2012, 13:53
  2. Mix Max Player Help
    By Empty_Space in forum Newbie / General discussions
    Last Post: 14th Mar 2012, 18:18
  3. What is max bitrate and max channels supported by PCM audio format?
    By Bonie81 in forum Newbie / General discussions
    Last Post: 18th May 2010, 23:35
  4. Max I Frames on DVDs
    By SCDVD in forum Newbie / General discussions
    Last Post: 4th Jun 2008, 18:19
  5. What's the max resolution for a SAP?
    By Bully9 in forum Newbie / General discussions
    Last Post: 14th Apr 2008, 17:31
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
