I have a Matsui DVD 110, and I am struggling to find a remote hack for (S)VCD playing capability. I did find one list which had the region code hack listed as well, and that worked fine, but the VCD hack listed there did not work. It was:
To enable VideoCD playback on this unit
1. Open the drive tray
2. Place any CD in the drive tray
3. Press the Stop button on your remote control
4. Press the Menu button on your remote control
5. Press the 9 button on your remote control
6. Press the 1-ALL button on your remote control
7. Press the Open/Close button on your remote control
8. You should now be in a new menu in which you can enable VideoCD playback.
THIS HACK DID NOTHING!!!! No menu came up, and it just closed my tray. Does anyone have the correct one for (S)VCD playback?
Thanks in advance.
Results 1 to 1 of 1
How you can use a stand alone DVD recorder and your Canopus 110
By fuzzblaster in forum Capturing and VCRReplies: 22Last Post: 3rd Oct 2010, 12:06 -
matsui m19dvdb19 - No sound from homemade films stored externally
By angelal in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2010, 08:48 -
matsui m19dvdb19
By pompeylil in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2010, 12:37 -
Matsui 330 - MP3 support
By harry4321 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Dec 2007, 14:31 -
Matsui 320 Hack
By ironchub67 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 23rd Jun 2007, 09:24
