Hi!
Does anybody know if TMPGEnc can be launched in shell mode or command line mode for batch processing? And if so, is there a list of commands and operations?
I know that TSCV (VCD authoring program) uses TMPGEnc in shell mode to encode of bitmap images to make an animated mpeg for VCDs menus.
Thanks!
Hi,
YES!
TMPGENC batch list processing is great. All you have to do is open your .avi file, choose your settings and add the convertion to the Batch List. After adding several clips you can start the batch conversion and let TMPGENC enconde all your clips. It's great for overnight convertion!
Regards,
Jose -
I don't know about a shell mode, or a command line mode, but I have been using batch mode more and more.
To use batch mode open the project wizard and setup an encoding job.
On page five of the project wizard there are two check boxes:
Start encoding immediately
Create another project(s) for batch encoding
Keep adding projects by checking "Create another project(s) for batch encoding".
On your last project of the batch check the "Start encoding immediately". Then the batch job will start. -
Thanks both of you for the replies.
But I think I didn't make myself clear. I need to make several demuxing and remuxing from a series of mpeg2 files. I'm using the "Mpeg Tools", in the File Menu to demux the audio stream of the file, for further conversion to wave files.
Then I need to split the stereo wave file into 2 separate mono files, reencode them back to mpeg audio (mono) and do muxing again with the video stream to make a 2-channel audio mpeg2. It's a lot of steps, that's why I need some batch processing to avoid the need of the long boring wainting.
I still need some ideas, but thanks anyway!
tsmuxer batch
By Tylerr in forum Video ConversionReplies: 0Last Post: 13th Jul 2011, 01:16 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 01:00 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 21:52 -
TMPGEnc Plus won't complete batch jobs.
By Timex in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2007, 00:13
