    Jan 2003
    So-cal
    I have Mydvd 3.5 and have the option of capturing straight to mpeg2 or in the show biz editor I can capture to avi. Im trying to put my home videos to dvd. I read in a couple of other posts that capturing vhs and 8mm,hi-8 is a wast to capture straight to mpeg2 because the resolution is to big.
    So would I get better quality if I captured my old vids to an avi at 360x480 resolution edit it then transcode it to mpeg2 ?
    Any help would be greatly apreaciated.
    Feb 2001
    Macondo, Puerto Rico
    HI jra111,
    Last week I capture several VHS to avi, convert them to MPG2 at 352 x 480 using tmpgenc and then then burned my dvd and it looks exactly as the VHS...
  3. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    From the limited experience I have I understand you would have to spend a small fortune to capture to mpeg2 in a quality to match huffyuv/picvideo codec avi's.
    It's a much longer process, but the end result by capturing to avi and converting/encoding would ultimately be worth it.
    Will
    Jan 2003
    So-cal
    I just tried it and it was a huge difference. I captured in Avi then transcoded to mpeg2 then burned it to a dvd and it was a 200% better picture Thanks for your guys help.
