Why does panasonic MPEG1 take 12 hours to convert divx to mpeg1 (VCD)
That depends on the settings in your encoder. If you use Multipass-VBR, the whole process takes very long because the video is processed several times to determine when the encoder has to use a certain bitrate (VBR = Variable BitRate).
Constant BitRate (CBR) is fastest because the file is only processed once, but VBR yields better quality.
Encoding time also depends on what encoder you use. I don't know about the Panasonic encoder, but Cinema Craft Encoder is faster.
There are only 10 types of people in the world:
Those who understand binary
and those who don't. -
Because the Panasonic MPEG Encoder is OLD (assuming you are using v2.x) and is only optimised for MMX.
The quality it gives for standard VCD is pretty good though...
Regards.Michael Tam
w: Morsels of Evidence
How to convert RM/RMVB to AVI or MPEG1/2
By kschang in forum User guidesReplies: 112Last Post: 11th Feb 2012, 20:56 -
Need MPEG1 encoder
By Xpenguin17 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 5th Oct 2010, 11:16 -
USB Mpeg1 Hardware Encoder?
By leebo in forum Capturing and VCRReplies: 8Last Post: 10th Apr 2010, 00:32 -
Need Help Panasonic HDC-HS250P (AVCHD), USB to Windows Media Encoder
By planet_bill in forum Video Streaming DownloadingReplies: 1Last Post: 13th Aug 2009, 15:40 -
Fastest program to convert avi to dvd is to long
By goheadtry in forum Video ConversionReplies: 12Last Post: 27th Jan 2008, 05:33
