I am editing my avi files from my camcorder with Premiere. The clip I am working on uses an audio sample rate of 32kHz.
I want to add a sound track using a file imported from my CD audio. However, the sample rate is 44.1 kHz.
I have read in the Premiere user guide that one should not mix audio with different sample rates.
Could that create audio or sync problems. Do I need to convert my CDA file to change the sample rate. How do I do that ?
yes - change the sample rate first with ssrc
http://fairuse.releaseme.org/files/ssrc-1.28.zip
Join .avi files, different video sample rates
By -mm- in forum EditingReplies: 22Last Post: 12th Oct 2014, 07:46 -
Premiere and sample rates
By tpapictures in forum EditingReplies: 6Last Post: 4th Apr 2011, 21:05 -
Adding audio track to MKV file
By SavageButcher in forum Video ConversionReplies: 2Last Post: 29th Mar 2010, 04:33 -
Adding new audio track to avi file
By skaleton in forum AudioReplies: 5Last Post: 11th Apr 2008, 14:29 -
DVD Audio To .wav Sample Rate Question
By xtreme469 in forum AudioReplies: 3Last Post: 29th Sep 2007, 10:04
