Hi all,
I have a strange problem with the "Intel Application Accelerator" IDE drivers: After installing it I can't use Video CDs any more.
As you probably know, those are written in a special way, using the "error correcting code" areas of the blocks for data instead in the main movie file.
Normally windows can use the files on those disks without problems, but with IAA installed the file always, reproducable 100%, shows up as corrupted, in PowerDVD as well as in a plain hex viewer. Uninstalling the IAA makes the VideoCDs work again, however of course the speed goes own noticably.
There is also another problem: The IAA diagnostic utility can't be opened, it complains on opening that the driver is not installed - but the driver does show up in the System Control panel, and a Benchmark also shows the much higher transfer rates.
My config:
Asus P4B board (which has a Intel 845 chipset), Celeron 1700, IAA 2.3 (but 2.2 has the same problems), Windows 98SE (I reinstalled it to see if that helps, to no avail), 40x ARTEC ACD-406 CD-ROM (but I tried a SAMSUNG 24x SCR-2431 as well, with the same result).
The newest Chipset INF driver from Intel was installed first, of course.
I'd be really thankful for any hint since my video conversions are now all useless. This is rather strange and all the troubleshooting docs on the Intel site, as well as VCDHELP.COM, web, and usenet searches, weren't helpful in any way.
Have a nice day,
Linards -
honestly "Intel Application Accelerator" has killed several systems of mine and i will never install it again ...
others seem to have no problems .. -
Could the IAA cause tmpeg not to open up avis? Ive been having issues with tmpeg lately and the only way i can get tmpeg to read the avi is to frameserve them through virtual dub to tmpeg, i'm pretty sure that its not a codec problem too cause it the video that i captured with my video card!! (Huffyuv) Any speculation would be appreciated thanks
ryanYou win some, and you lose some, and some get rained out... -
Originally Posted by ryanreko
If you have problem open DV video, DC30+,MJPEG captured video or any AVI VFW
Then try to change the settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the AVI VFW and increase the priority to 1 and try open the video.
tearex
I have the ASUS P4266, the 845D chipset and a 1.8A Pentium 4 and have run with W98SE and now Win 2K Pro SP3 with the Intel Application Accelerator installed and have never had problem 1. Have you done a clean install and installed the Intel Application Accelerator after you install the OS but before you install any applications? I would be suspicious of the driver problem. Have you talked to Asus tech support?
PS I played a VCD, authored and burned with Ulead DVD Movie Factory 1, with PowerDVD V4.0. -
I forgot to re-enable DMA transfer mode after uninstalling IAA. After I switched to DMA, it is now just as fast, without IAA. Fine with me, I don't need drivers that don't improve anything and just cause trouble. So the problem is solved. Thanks to all who responded.
Linards
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
Was it the iphone that replaced the word "program" with "application"?
By yoda313 in forum Off topicReplies: 6Last Post: 16th Mar 2011, 08:52 -
Power supply sticker reads "Intel only".
By Arch3type in forum ComputerReplies: 3Last Post: 7th Feb 2011, 22:52 -
Problem with "Application Support" folder contents (& .flv co
By Fostermeister in forum ffmpegX general discussionReplies: 2Last Post: 12th Dec 2008, 13:59 -
Whats "application/x-pn-imagemap"?
By eu63ne in forum Newbie / General discussionsReplies: 4Last Post: 8th Oct 2007, 08:50
