When I am trying to burn DVD-R's and -RW's I am only allowed to write at 1X. Is this normal? The box says that the DVD-R's are up to 4X (I know you would need 4X discs) and the -RW are up to 2X
My +RW disc burns at 2.4X as advertised? Any suggestions?
Thanks.
Standard speed for -R or -RW is 1x. For faster - burning you need media that can be burned at 2x or 4x.
Is there any guideline for what type of media we should be using for what?
ie. my main purpose for buying my DRU500A was to backup/keep a record of various files on my computer (large database files, video clips, mp3z, software files, etc..)
Should I be using DVD-R or DVD+R?
Also if I wanted to backup a movie DVD I bought, would I use DVD-R or DVD+R
I never used CD-RWs in the past, what would I use DVD+/-RWs for? The same as above but for when I want to use the disk again?
Thanks. -
For data backup I dont think it really matters. You'll want to burn multisession so you can add stuff later. For movies though you need to use a media compatable with your stand alone DVD player and will be best served in DAO mode.
Not an expert but this is my take on it so far.
My Sony CD/DVD player (NS55P) would almost only play sony discs.
By valdes001 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jan 2011, 11:03 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Trouble with SONY DVD+R disc and SONY player/recorder
By Winston99 in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2010, 23:54 -
Burning DL DVD Issues (Nero 8, Sony Encore and Ashampoo 8)
By JJ - Tampa in forum Authoring (DVD)Replies: 3Last Post: 14th Jul 2008, 22:43
