Are there any good quality FREE DV codecs out there? The Canopus and Mainconcept don't support DV export. I am after a codec for VDub (and TMPGenc) that will let me export a file back out as a DV format avi.[/b]
I have not seen any free DV codecs. You can get a free DV decoder, but not encoder. However, the DV codec can be bought for less than $50. (Mainconcept "super-fast" DV codec)
Ah well, time to shell out some more hard earned cash!
Thanks anyway. -
Although I have a hardware DV-Capture-card, I also have software DV-codecs.
I don't know how the use of this codec exactly is, but I can export using VDub in DV. Possible it's the same method as with other codecs.
Though I don't know whether it would work on a system without a hardware DV-codec adapter. It might be that the calculations needed to create a DV-source requires hardware designed for it.
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
Recording with high quality and good conversion methods (snagit & codec q.)
By mukunku in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2010, 23:43 -
good editors? free?
By sboarder2011 in forum Newbie / General discussionsReplies: 8Last Post: 6th Oct 2009, 15:30 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18 -
Best free DIVX codec?
By DonGallego28 in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 18:45
