So i wanted to test speed difference between TMPGenc and MainConcept..
I really couldnt believe the results.. But here they are..
oh yea, this is on a 500Mhz AMD K6-2 with 160MB RAM
Movie : Black Hawk Down
Runtime: 144 min
TMPGenc
using VBR 9100/4500/2500
Motion -> High
Total Time To Encode
125 Hours
Frames Per Second Est. 0.57
MainConcept 1.3.1
Motion -> 8 (7 is the middle option, so i would assume 7 is equal to TMPGenc's "Normal" Choice.
18 Hours
Frames Per Second Est. 4.0![]()
Do the math, that is 6.9 times faster
At that speed, if i could encode a 100min VCD in 8 hours on TMPGenc, i should be able to do the same in MainConcept at almost real time.. I will definately have to try that out.
Results 1 to 15 of 15
A few random thoughts:
1) your bit rates seem to be different for the two different runs.
2) did you actually let your computer run 125 hours encoding a movie?
If I saw a 125 hour eta I'd cancel the job and try something else!
3) I'm not certain that the results of a 500mhz k6-2 will scale to
a 2GHZ P4. -
Ditto:
I have found when I start TMPG it says 3 hours...and when I'm done it was 10 (2-pass...etc etc) or the opposite...says 12 hours and takes 4 ( usually CBR...go figure?).
How about 5 minutes of video and a side-by-side comparrison?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Yeah I noticed that too, I think its a typo rather than a difference.your bit rates seem to be different for the two different runs.
Well no since the K6 doesn't support hyperthreading (btw I have no idea how much difference this makes in practice)I'm not certain that the results of a 500mhz k6-2 will scale to
a 2GHZ P4.
There is also a slight price difference between the two, with Mainconcept costing more than a good hardware encoder, I think I'll stick with Tsunami.
Obvious question but how does the quality compare? -
The bit rates were a typo, they were the sameOriginally Posted by incognito
yea, trust me, i thought about it.. but im kinda used to that kinda ridiculous time frame2) did you actually let your computer run 125 hours encoding a movie?
Maybe not.. All i know is that im MORE THEN HAPPY with 18 hours for a DVD->DVD-R re-encode on a 500Mhz3) I'm not certain that the results of a 500mhz k6-2 will scale to
a 2GHZ P4. -
125 hours was the final time.. When i first started it, it told me it would be 80.. but it lied.Originally Posted by Gazorgan
As for the 5 Min video clip.. i'll hafta try that out -
Main Concept works much faster on my 2.0GHZ system as well.
Easily 5 times the speed of TMPG
What confuses me is the same job runs much faster on Sound Forge VEGAS 3.0
than
on ADOBE PREMIERE 6.5
both include the MainConcept MPEG engine...what gives?
Sorry I don't have actual figures, but
2 x faster seems possible!
Shuttle AB-30
1GIG SDRAM(133) -
upgrade adobe 6.5 mpeg encoder and the speed should be about the same -- but always a little slower through premiere excpet if you have dual or hyperthreaded system (update to premiere also adds hyperthreading/multiproccessor support)
MainConcept is much faster. I don't know about 6.9x, but easily 4x on a 2.0 and 2.4 P4. What I care about most though is quality and reliability. With my set up both MainConcept and TMPEGenc run circles around CCE on stability. CCE is still the leader in quality of output, but in my opinion that gap is narrowing rapidly.
I've been fooling around with MainConcept a lot lately because of the speed and I'm starting to get 1 pass results that are very equivalent to the quality of multipass TMPEGenc, without using anysort of unusually high bitrates, and without claiming to be an expert in maximizing quality for MPEG encoders! Assuming they don't break anything when they implement multipass for Mainconcept (supposedly with v.1.4 this month), I'm betting that the quality will pass TMPEGenc if not give CCE a run for the title. I'd love to see if some of the same collective expertise that is focusing on TMPEGenc would try optimizing MainConcept what the results would be. -
OK, ran yet another test with TMPGenc and MainConcept
This test was converting the trailer for Hackers off the DVD to standard VCD.
Total Frames : 4974
TMPGenc
Total time: 1567 seconds (00:26:07)
Time spent per frame: 0.315 seconds
3.17 Frames Encoded per Second
File Size : 28195KB
MainConcept 1.3.1
Total time: 776 seconds (00:12:56)
Time spent per frame: 0.156 seconds
6.41 Frames Encoded per Second
File Size : 28169KB
As for quality.. here is some pictures to compare...
MainConcept 6:1 Zoom
TMPGenc 6:1 Zoom
here is the screenshots at 352x240
TMPGenc
MainConcept -
From a distance, looking at your pics, I thought you were encoding the movie Mask (with Cher).
I like the idea but those single screen shots tell us nothing really... I mean there are no obvious distortions..I cant believe main concept CANT do multi pass... a bit bloody lacking!
BTW 125 hours .. cost of leccy = £18.90 perhaps?? or was this done at work or your pc is connected to the street lights
I too see no difference, cept the MC pic looking a tab bit softer.. but it was just a comparison to see what kind of quality per frame you'd get.Originally Posted by RabidDog
i assume leccy = electricity (im american, forgive meBTW 125 hours .. cost of leccy = £18.90 perhaps?? or was this done at work or your pc is connected to the street lights
in anycase, my computer is never off anyways, so it wouldnt make a difference to me -
Remember, this means that your processor only has MMX instructions.Originally Posted by johneboy
If these programs are run on a CPU with SSE and SSE2 as well (e.g., P3, Athlon, P4), the benchmarks may be completely different.
Regards.Michael Tam
w: Morsels of Evidence
haha, wow, it echoes :P
By eccentricity in forum MacReplies: 5Last Post: 13th Dec 2007, 09:18 -
WOW its gettin hot
By Heywould3 in forum ComputerReplies: 14Last Post: 6th Nov 2007, 18:10 -
TMPGEnc Xpress, MainConcept, H.264 and QuickTime Compatibility
By PuzZLeR in forum Video ConversionReplies: 6Last Post: 27th Oct 2007, 04:05 -
Wow I found you guys
By alanr in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 15:27 -
pc reboots when wow starts up
By Mr anderson in forum ComputerReplies: 8Last Post: 26th Aug 2007, 07:01
