I'm trying to convert AVI to VCD, but having problems because of the AVI. Here is the info from V-Dub
640x480, 15.000fps
Is there a way to convert this to a VCD? Do I have to convert to an AVI type that is supported by VCD? Thanks.
[/img]
You can convert it, but it's going to be noticeabley jerky. Not much you can do about that.
You can convert it to 29.97/30 fps without much headache ( nice multiple of 2 there ). You could als convert it to PAL relatively simply ( 3:5 ratio is relatively clean). The end result is still going to be jerky, so donm't get your hopes up.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Let me clarify. A 15 FPS video is alwasy going to have 15 fps of content. No amount of conversion can take this away. At 30 fps, you going to have 15 true frames and 15 duplicate frames, hence it's 'still 15 fps' and the jerkiness is percieved, and not related to the encode or playback.
As the saying goes: you can downconvert, but never upconvert. Or the end product can never have a higher quality than the input: you can never convert a VCD to SVCD and have it look like a DVD ripped SVCD. Filters not withstanding, and that is only an issue for caps, not DVD's in general.To Be, Or, Not To Be, That, Is The Gazorgan Plan
WinDV acting goofy
By stantheman1976 in forum Capturing and VCRReplies: 5Last Post: 8th Feb 2009, 19:46 -
MP4 29.97 fps to AVI 25 Fps
By videopetur in forum Video ConversionReplies: 4Last Post: 20th Jan 2009, 06:37 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
framesize problem with Mov to DVD
By Burny in forum ffmpegX general discussionReplies: 5Last Post: 24th Mar 2008, 05:57 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 08:35
