I have a couple of MPEG1 files that I got from friends that they captured as MPEG1. I burned them to VCD's and it looks not too bad but I wondered what it would look like as an SVCD.
However, since the file is captured as an MPEG1, would running it through TMPG to encode it as an MPEG2 really do anything? I mean if the resolution was 352x240, how can it be re-encoded to 480x480?
Also, the same question applies to bit rate. Can I double the bit rate of my MPEG1 file to improve quality and have a bigger MPEG1 file or is it impossible since it wasn't captured at a high bitrate?
No it will not make any improvement at all. Likewise doubling the bitrate will only make the files bigger it will not yeild any visual improvement.
The best it will look is exactly the same. Typically it will look worse, blockier and washed.
There is no reason to convert VCD to SVCD, you gain nothing and lost qualite with an additional conversion.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Only DVD_NTSC folder with MPEG2 file inside after converting
By big_b0i in forum Newbie / General discussionsReplies: 4Last Post: 30th Jun 2011, 08:23 -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 18:39 -
Why does XVID avi file balloon in size when converting to mpeg2 or dvd?
By im2020 in forum Video ConversionReplies: 3Last Post: 11th Aug 2010, 12:30 -
Converting MPEG2 Audio from AC3 to MPEG1 Layer 2
By jrisch in forum Video ConversionReplies: 8Last Post: 8th Dec 2009, 20:28 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 10:58
