I have Roxio Easy CD creator 5.1 Platium on a Dell 4400 with Windows XP. I installed VCDEasy 1.1.3 for burning SVCDs. So I had to install the aspi layer using forceaspi. VCDEasy seems to work fine. The only problem I have is once VCDEasy burns to a CD, Roxio no longer can access the drive. If I reboot then Roxio can access the drive again. I could not find any info about this on Roxio or cdrdao web sites.
I know most people on this site seem to be using Nero. I don't really want to switch to Nero because I am quite happy with Roxio for data and music CDs. I rarely burn coasters with it and I also like its labeller program. I don't like the VCD program in Roxio, but that is why I have VCDEasy which is great.
Is there any way to make Roxio and the VCDeasy/cdrdao co-exist together?
Tim
I have the same problem. I have to reboot to use ECDC 5.32 after using VCD Easy. Another problem I found, and apparently fixed was that the ECDC 5.32 upgrade did not work until I updated the ASPI drivers to 4.71. I was hoping this would fix the ECDC vs VCDEasy problem, but it didn't. I'm still looking to find out what is causing the problem.
Jim
IRQ is my cat. He interrupts me anytime he wants attention.
Follow-up. Haven't found a solution, but have sort of a workaround.
I find if that I burn a disk with ECDC first after a reboot, then I can burn a disk VCD Easy and go back to ECDC with no problem. Must be that CDRDAO gets to something first, but if ECDC gets it first, CDRDAO doesn't care.---------------
Jim
Can Roxio USB capture be used without Roxio's software?
By miamicanes in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2012, 16:30 -
Need Alternative To Roxio
By mlb32704 in forum Newbie / General discussionsReplies: 23Last Post: 9th Apr 2011, 18:50 -
Roxio ?
By reygato in forum EditingReplies: 3Last Post: 20th Apr 2010, 07:50 -
Roxio Popcorn 3 - HELP?
By jphuber1959 in forum MacReplies: 8Last Post: 2nd Dec 2007, 13:50 -
Roxio vs Nero
By gthorley in forum Authoring (DVD)Replies: 25Last Post: 23rd Aug 2007, 02:08
