Ive been searching and gathering info for a week now. I was thinking about the Daewoo DVG 6000. The Philips 724AT is not available in europe i think so that wont be an option.
i need a player wich plays (s)vcd/vcd/mp3/cd-r/cd-rw/dvd-r/dvd-rw/svcd-subs
Important things are
-It must be able 2 FF and REW (S)VCD good
-DVD-R and DVD-RW must be good playable
I believe the daewoo meets this requirements. Can someone confirm the 2 things above?
Thanks for helping me out.
I have a Daewoo DVG 9000, which is the same as DVG 6000 but mine has progressive. It definitely does not play DVD-RW. It plays DVD-R just fine. It is also very good playing both PAL and NTSC and will set the output automatically to suite your TV.
One problem though. Anytime the power is disconnected for a while, you'd have to turn it on and leave it without a disk in it for at least one hour. Then it will recognize a disk. Otherwise, it will malfunction.
How to make USB video work on Philips LED series 6000 TV
By Joaquim Brasil in forum User guidesReplies: 3Last Post: 14th Sep 2013, 15:58 -
Adapter for Dell Inspiron 6000 drive
By bevills1 in forum ComputerReplies: 4Last Post: 31st Oct 2008, 13:31 -
Code Free does not work daewoo dvg 8300 se
By ramona in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Feb 2008, 11:52 -
Did I Make A Good Choice on My TV?
By tcheema in forum DVB / IPTVReplies: 6Last Post: 18th Jan 2008, 15:06 -
Just ordered a Canon HD camcorder, did I make the right choice?
By rcguy1 in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2008, 09:27
