I have edited a home made DV using Pinnacle studio 7 and converted this to mpeg2. Then I used Nero to burn a svcd to be able to look at the film on a DVD-player. But it doesn't work despite the DVD-player supports svcd.
What have I done wrong???![]()
Did you try with CD-RW?
You did select create svcd in Nero right? the svcd should look like this http://www.vcdhelp.com/svcd#struct
Did you read the compatibiliy list comments? Maybe it didn't work for some(different dvd player firmware or something). -
Honestly, God knows, but the first place to start is to grab one of the SVCD sample files from here and try that. The point of this is to eliminate Nero and your DVD player as the cause , which will make sorting out your problem a lot easier.Originally Posted by brostacheck
Sounds like Pinnacle studio, might be producing invalid Mpeg 2 files.Originally Posted by brostacheck
Check its output
Super Video-CD PAL (MPEG-2 480x576 25fps CBR 2520kbps, Layer-2 44100Hz 224kbps)
Super Video-CD NTSC (MPEG-2 480x480 29.97fps CBR 2520kbps, Layer-2 44100Hz 224kbps)
Super Video-CD NTSC Film (MPEG-2 480x480 23.976fps CBR 2520kbps, Layer-2 44100Hz 224kbps)
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 21:23 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 10:40 -
how to play seamless loop svcd's
By markwest in forum Authoring (VCD/SVCD)Replies: 8Last Post: 11th Aug 2007, 15:06
