Hi!
I have copied and frameserved a PAL movie using CladDVD XP. When i open the copied movie with winDVD or similarar it's works perfect! But when I encode the movie to PAL SVCD using TMPGenc 2.0, the video ´stutters but the audio is fine. This happens both on my computer and if i burn the movie to an CD-ROM and run in my home DVD player.
Could this be a tmpgenc issue? or maybe I have done something wrong in the config.?
I used 'force film' when copying the movie to my harddrive. Maybe this only works with NTSC?
I don't know much about ripping DVD's but I do know you are right on that point. 'force film' is only relevant to NTSC.Originally Posted by trimtram
OK! But since the .VOB files is on the harddrive already, I only have to frameserve them again, but without 'force film' then?
Through nature's inflexible grace i'm learning to live -
what program do you use to frameserve the vobs with?
You win some, and you lose some, and some get rained out... -
I use the internal frameserver capabilities of CladDVD XP (it has an built-in version of DVD2AVI).
Dual Layer burn issue with TMPGEnc Authoring Works 4
By am_dew in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2012, 09:36 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 15:10
