I assume the best way to author the files(after using dvd2dvd-r) to vob's is with ifo-edit,but how can i get subtitles?
After authoring the files, can i burn them with nero or are there a few more steps to go........?
Jesprulin
you would have to use a authoring program that accepts subtitles like dvd mastreo. just make sure you save the subtitles when you load your dvd in to dvd2dvdr.
Jesprulin
If you are ripping Pal Movies DVD2DVDR will rip and author the movies automatically with subtitles and chapters using ifoedit.
If you are ripping NTSC films you will need DVDMAESTRO to author along with Subrip and chapterxtractor. -
you are right,i'm ripping to pal movies so ifo-edit finishes the job indeed.
It works great,and the movie looks fine(including the subs)so thnx to all of you for your support!
Jesprulin
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 22:51
