In the process of converting my DV tapes to DVD, I have created with Studio 8 and burned direct to DVD-RW to test first (i.e. I dont have the DVD files saved to hard drive)
I now want to burn onto DVD-R. How do I copy the DVD-RW to DVD-R ? I tried copying the files from the DVD-RW to my hard drive and then writing to the DVD-R using Roxio EasyCD but the resulting disc cannot be played in my standalone (although it works on the PC).
Any ideas ?
Don't know about Roxio, but Nero can do this. Either do a disc to disc copy if you have a DVD-Rom as well as a DVD-writer in the same machine, or copy the files to your HD and write with Nero using either DVD-video mode or UDF/ISO mode, both should work.
I don't understand what you have done. Did you ever author the DVD?
SLK001,
I authored the movie using Studio and burned to DVD-RW. It worked perfectly and so I wanted to copy the contents to DVD-R. Basically, I copied the VIDEO_TS folder with all contents to hard drive and then used Roxio to burn to DVD-R (using Data DVD mode). This worked on my PC but wouldn't play on my standalone (The DVD-RW did) -
use a program like recordnow max or nero that willmake it compliant when it sees a videots folder. I do not know if roxio makes it compliant if it sees u are making a dvd. The two I said will as long as u do not change the setting for it not to. Good luck. Had roxio long time ago but IMO it sucks for anything but a really new guy making Audio cd. Good Luck again and Have a Super Day
Thanks.....
Just downloading the trial of Nero. Will give it a go.......
Cheers
Chris
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
