Hi
Just a simple question I hope
If I take two MPEG VCD files and join them, in TMPGEnc for example, will there be a drop in quality from the original VCD file in the new file.
Along the same lines if I use TMPGEnc to cut a portion of a VCD file out will the resultant file loose quality once TMPGEnc has finished splitting it ?
Thanks in advance
Thanks for the prompt reply
Does that also mean that if you were to encode a file to VCD and then run it through the encoder again set to VCD there also would be no drop in quality ? Just Curious
When you're cutting or joining, there's no encoding involved, thus no drop in quality. If you however encode something (using MPEG) there will be some loss in quality, regardless of input format.
So, even if you encode using exactly the same settings as when the MPEG used as input was created, there will be quality loss.
If the encoder was really clever, it could discover that the input and output format will be exactly the same, and refuse to encode (resulting in no quality loss) but that's not the case for any encoder I've come across.
/Mats
Questions about video re-encoding and downscaling - quality loss? bitrates?
By Veid in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 01:06 -
Combine Mpeg-2 Files (without re-encoding or loss of quality)
By Anonymous642 in forum Newbie / General discussionsReplies: 2Last Post: 26th Oct 2011, 07:58 -
By MGadAllah in forum EditingReplies: 33Last Post: 25th Sep 2011, 20:53 -
encoding .VOB to .FLV with least loss in quality
By altavistasf in forum Video ConversionReplies: 9Last Post: 15th Oct 2010, 18:33 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 02:03
