Sometimes when I encode avi to vcd with TMPGEnc (2.56) the audio is shifted over the full movie with aboud 160-180 ms. even when the audio on the avi is OK.
As anyone exeperience with this problem ???
In wot player u getting the delay? WMP or your DVD player?, if its the DVD player then u may need to mess around with sound delays to get it right. My DVD player requires a time delay of 500ms for mpeg1 but none for mpeg2. Where did u get the figure 160 -180ms from? Trial and error or some prog?
Thanks for replying.
I have captured from dvd without audio/video synchrone and the result was OK within WMP. After encoding with TMPGEnc there is an audio shifting in the same WMP so I checked the avi in virtualdub and here I see also that audio shifting.
So the problem is not TMPGEnc but the capture manner that I used (without audio/video synchrone). Infact TMPGEnc did is job verry well.
I'm using now vdub as frame server to resync. the movie with an negative time-delay to solve my problem, and works very well also.
My reasson to capture without audio/video synchrone is becausse I use an older PC (P2 400Mhz W2k). Without the sync. I can capture without one framedrop in full RGB24 color. But after than I need to correct the sync.
All by all this is a good HQ-capture alternative when using slower PC's or when you have problems with framedropping by VHS-capturing.
Help! Mpeg2 encoder shifts image up and adds a line at the bottom
By Asterra in forum Video ConversionReplies: 13Last Post: 10th May 2010, 19:57 -
Getting Audio before TMPGEnc?
By chronic777 in forum Authoring (DVD)Replies: 2Last Post: 5th Apr 2009, 08:52 -
TMPGEnc no audio
By jay_lubb in forum Video ConversionReplies: 4Last Post: 23rd Mar 2009, 12:16 -
No audio in TMPGEnc
By jay_lubb in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 03:26 -
TMPGenc and audio file
By JosieB in forum Video ConversionReplies: 10Last Post: 27th May 2007, 05:33
