Hi there,
My DVD2AVI results in a very bad quality wav-file? How is this possible?
I ripped my Billy Joel Ultimate Collection DVD with Smartripper. Then I loaded the vob files in DVD2AVI and saved the project. After a while, but before the conversion was finished, I wanted to check the resulting wav-file and stopped the process. The wav-file sounded horribly in MediaPlayer, with only the music very far on the background with lost of noise. How is this possible?
I am not sure I made the correct configurations in DVD2AVI, but I remember adjusting the defaults to get 48--> 44.1 audio (high) or so. Do I need to get rid of this or adjust other items on the audio menu?
Please help?? Many Thanks!
Marcel
Try using DVD2AVI's demux setting. If you get an AC3 file you can convert (and resample) much better with HeadAC3he.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Encoding WAV and M2V to AVI [high quality]
By duudo in forum Newbie / General discussionsReplies: 2Last Post: 28th Feb 2009, 06:57 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
