I've got an idea, maybe somebody can help point me in the right direction...
What I want to do is take the VCD XML schema and create an app that will automatically convert an VCDImager XML file into an ASX XML metafile.
The idea being that you just create your VCDImager XML and then run this app and the output will used for the ISO autorun on PC's.
I don't know enough about XML yet to do this, but I'm a fast learner.
Any links or hints would be helpful. Thanks!
