  1. I just purchased a panasonic dmr-e30. I picked up some Memorex DVD-R, Single Sided version 2.0 When I put one in the recorder, it scans the disc and then displays "U11". If I press the record button, I get a message telling me that the machine can't record to the disc.
    I have successfully recorded to the DVD-RAM disc that was packaged along with the unit.
    Anyone have any ideas for me? Just try another brand of DVD-R? I found a website that lists Memorex DVD-R as a suggested accessory for the DMR-E30, so it surprizes me that they would be incompatable.
    Thanks in advance,
    slamotto.
  2. i understand... but cheer up.
    i have same prob,somehow the disc or dye not compatble with the drive.try this put the blank into dmr,let it spin for 5 min,doin nuthin,then press record.50/50 chance it records,if it shuts down,turn machine on,let the disc spin , then rec. usually it shuts down when disc is 100% empty,not when somethin already there from before...try accu dvd-r from cdrdvdrmedia.com
    to dvd or to dvd
  3. hi slamotto
    i have my panasonic e30 for a few months and still get some u11 messages from different dvd-r disks. my memorex disks like you used seems to be okay. i found out that buying cheap disks doesnot pay. the panasonic disks work great. course they are not cheap. i found that if you keep trying the disk it will work sooner or later. clean the disk also. good luck.
  4. I have had very good luck with some cheap DVD-R in my pan e30s unit.
    I either bought them from meritline or cdrdvdrmedia and they were probably around 80 cents each then in lots of 100.
    They have a white surface and purplish dye on the obverse.
