The movie plays flawlessly using WMedia Player but when Nero prompted me to re-encode I attempted to open in TEMPEnc and it crashes. In VirtualDub I get: "MPEG Import Filter: pack synchronization error" What should I do?
Ash
You have a Mpeg 2 file, it wont load in Vdub, and unless you have Mpeg 2 support it wont load into TMPGEnc either.
Try installing Power DVD 4, its Mpeg 2 codec works with TMPGEnc + -
I installed power dvd 4, rebooted and TMPGEnc is still crashing when loading the mpg. Why is this happening?
Ash -
Sounds like there is a clash with some other Mpeg 2 filter, since you could already play Mpeg 2 files, what ever filter is installed, you may need to get rid of it. Try to get to the stage where you cannot play Mpeg 2 files, then install Power DVD 4 again...
Try the Ligos Mpeg 2 filter (Ulead MediaStudio Pro etc), also check
TMPGEnc
Options > Enviromental setting > VFAPI Plugin > Right click the MPEG 2 Decoder and select higher priority. Do this sevral times until its at the top.
I'm trying to open .WebM in VirtualDub
By alinhoalisson in forum Video ConversionReplies: 25Last Post: 22nd Sep 2014, 06:20 -
Open h.264 in VirtualDub
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 6th Nov 2011, 21:21 -
How to open WMVA with VirtualDub?
By Zeokat in forum Newbie / General discussionsReplies: 5Last Post: 24th Oct 2011, 04:47 -
Virtualdub can not open xvid
By quxote in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2009, 01:11 -
VirtualDub can't open my mpg from camcorder
By ssalim in forum Video ConversionReplies: 3Last Post: 2nd Dec 2008, 17:46
