  1. I was making a copy of one of my DVDs and when time came to convert it to VCD and burn it it wont let me select my CD Writer! It says that ''CDRDAO disabled in the VCDEasy settings page...'' When I go to the VCDEasy settings page to ''Enable CDRDAO Integration'' I get this message...''No CD Writer/reader found or ASPI drivers problem''
    What do I do? Is the ASPI drivers the problem? It says at the bottom of the page ''ASPI seems valid: No''
    Seaside, CA
    If it says ASPI seems valid: no, that is your main problem. In that case I suggest you go to: http://www.afterdawn.com/software/cdr_software/cdr_tools/frcaspi.cfm , download the ForceASPI drivers, install them and reboot. If after you reboot, it shows "ASPI seems valid: yes" then on the CDRDAO settings page, select generic-mmc as the force driver for the CD Writer, select your specific CD Writer in the dropdown menu for that section and check the force execution box. Now you should be able to burn using CDRDAO, which is the CD burning program built in to VCDEasy.
    If it still doesn't burn then the second thing to check is VCDEasy set to "Simulate Burn" that is right on the main page. Uncheck "simulate" and check "burn".
  3. Thank you so much! That fixed it!
