Is there a way I can record VHS tapes onto my PC and then burn them on a CD-R? If so what do I need to buy? Do I do it with a VCR/TV? Or whatever?..lol Im new.
Another one of these....
OK, move your mouse to the left of the screen.
Refer sections:
NEWBIE
CAPTURE
FAQ
it's all there..."speed's just a question of money. How fast can you go?" - Mad Max, 1979 -
If you are looking for an inexpensive solution, I've am using the AverTVStereo card. I capture it to AVI using ULead6 Video Studio then encode it to MPEG1 for burning to VCD. It works for me, and the quality looks pretty good to me. You can replace ULead6 VS with several pieces of freeware, but this is the no-hassle approach. If you want to use freeware, I was able to use VirtualVCR to capture, TMPGenc to encode, VCDImagerGUI to author, and CDRADO to burn.
You can capture directly to MPEG1 using the AVerTVStereo card, but I have a slow PC so I did it in 2 steps.
Hope that helps.
Which recorder and video enhancer do I need to record my VHS tapes to DVD?
By cnyeco1 in forum Authoring (DVD)Replies: 6Last Post: 26th Oct 2013, 06:13 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 21:36 -
For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?
By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 17:27 -
Can VirtualDub record VHS tapes to AVI format?
By gregnovella in forum Capturing and VCRReplies: 4Last Post: 29th Apr 2009, 00:37
