Ok finally got my Premiere MPEG encoder to work. I just converted an AVI to a MPEG using the SVCD setting in the built in converter. I went to EasyCD creator and hit "create SVCD" and go this message "The file will not work in an VCD player. To make compliant, you will need to use an MPEG encoder that supports VCD encoding. So then I tried my Nero program, and it worked! Popped it in my DVD player and its very jumpy. Anyone had this, or know what I'm doing? Not sure if this helps but in Details on EZCD creator it says:
Frame size 480X480 and has a red X=not acceptable
Video Bitrate 2376 kbs X
Total Bitrate 32705 kbs X
System Clock Reference 2400 X
the rest say probably acceptable. Thanks for any tips
Results 1 to 1 of 1
Encoding a vob file to use in premiere pro
By spongela in forum Video ConversionReplies: 2Last Post: 17th Oct 2011, 18:31 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Adobe Premiere H.264 Encoding
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 70Last Post: 27th Aug 2009, 02:24 -
Export DV AVIs without re-encoding in Premiere?
By moxiecat in forum EditingReplies: 1Last Post: 2nd Aug 2009, 03:04 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 21:48
