I recently purchased a jvc hr-xvc1u combo it is suppose to play vcd s, as well as other formats. My problem is the vcd's that I burn start about 5 min. into the movie. I have tried to get to open a menu, but the player won't do it. I use Easy Cd Creator to burn them, and TMPEG to convert. I have no problem getting them to work in my Apex AD-1500, it works great. Do you have any suggestions? I don't want to have to take it back. Thanks.![]()
Results 1 to 1 of 1
.avi files that won't work correctly!
By RolloSwe in forum MacReplies: 10Last Post: 24th Feb 2011, 11:45 -
By RolloSwe in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 17:41 -
DVD Doesnt Play Correctly On Stand-alone Player! (Skips)
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 16Last Post: 12th Sep 2008, 20:07 -
Panasonic DMRES45V DVD remote doesn't work correctly
By cep8719 in forum Newbie / General discussionsReplies: 2Last Post: 27th May 2008, 12:00 -
DVD player that will play Divx correctly.
By ThaDraGun in forum DVD & Blu-ray PlayersReplies: 6Last Post: 15th Oct 2007, 08:59
